car doesn't rev past 8000-8200 rpm
engine is fully loaded ford cosworth
no limiters
no fuel cut
no launch control
afr at full throttle is between 12:1 - 13:1
ignition advance is around 28 degrees
no misfires.
no trigger errors.
what can be the problem ?
any comments ?
no limiters
no fuel cut
no launch control
no misfires.
no trigger errors.
any comments ?
Emu Distributor / Tuner
Re: car doesn't rev past 8000-8200 rpm
Post log file
here is the file & log
- hs2.emulog
- (357.17KiB)Downloaded 121 times
- hs2.emu
- (78.08KiB)Downloaded 120 times
check time 8:10 in the log.
I can't see any problem in the log..
Dwell error is very low so it is not trigger issue. No spark / ignition cuts.
Seems like engine problem (are the cams properly set ?)
Is this "soft" or "hard" ?
what do u mean buy soft or hard ?
Does it seem to loss power or misfires (more sudden) ?
- Kisielisodd
- ECUMASTER TEAM
Try to lower dwell time from 3ms to 2ms and check if it will help.
already tried that. doesnt help.
we've found a cam timing error.
after re-adjustment - I'll tell you the result.
