Arduino + ecumaster?
Has anyone looked into printing out the data from the ECU master to an Arduino?
Re: Arduino + ecumaster?
Hi!
The easiest way is to connect to extension port (serial) and use AIM PROTOCOL
- AIM-ECU protocol.pdf
- (55.94KiB)Downloaded 289 times
Can I run a laptop while reading data from serial connection? Also can you tell me what kind of serial connector the ECU master is using I can't seem to find the right kind of cable needed to read the pin outs.
Here is a pinout of ext port.
It is independent of USB connection so it works also when EMU is connected to the laptop.
If you need a connector please contact us at info@ecumaster.com
Well, good idea for me to play with!
Is it possible to pull this data off the USB FTDI interface on the det3? My EMU doesn't go in until this weekend.
For DEt3 it is a little bit more complicated and we do not have documentation for it.
2wheels1man
How much mA can I safely pull from the 5V pin please?Jadzwin wrote:Here is a pinout of ext port.
I need 200mA @ 5V for my dash. Will it handle it or do I need to use voltage reg from 12V?
Also, will the XLR microphone MIC 325 connector fit?
You should use additional voltage regulator. The connector will fit
2wheels1man
Is there a protocol that uses constant frequency for all data?Jadzwin wrote:Hi!
Where all data is send every tick. Like a sentence of constant size.
for example:
1. rpm, tps, IAT, checksum
2. rpm, tps, IAT, checksum
etc..
This is the way DTAfast works for example.
I've created a Dash for the DTAfast ECUs and I'd like to use it with EMU without reworking the code from ground up
Hello guys,
is there some more informations about the other RS232 protocols? Because the values in the AIM protocol are not so mutch, for example EGT2, EGO correction, etc. is not there.
2wheels1man
Sent you a PM.Jan32 wrote:Hello guys,
I'm interested in this. I've been thinking about a way to replace the stock cluster. I've seen a few Arduino powered gauge cluster but that's way past my scope.
