vvt map
calvin briggs
hi there, i am looking for a VVT map for the ford duratec 3.5 V6... I know that you have tuned one such engine and i was wondering if you could share the VVT settings and the method which you used to achieve them. This engine has vvt on the two intake cams only. Thanks
calvin briggs
Re: vvt map
wow....... not one reply...... jakub..... you were the person who set-up the vvt....... if you do not wish to share the info, or if you are not allowed to share it, then you could have at least responded and said something.........all the ECUs out there have basically the same features, its the tech support that wins over the customers......your lack of a response does not show that you are aware of this
Re: vvt map
Why don't you send me a message directly?
Re: vvt map
contact your dealer - if you would buy this from our dealers or distributors they know product perfectly and im sure they will be able to help..calvin briggs wrote:wow....... not one reply...... jakub..... you were the person who set-up the vvt....... if you do not wish to share the info, or if you are not allowed to share it, then you could have at least responded and said something.........all the ECUs out there have basically the same features, its the tech support that wins over the customers......your lack of a response does not show that you are aware of this
- Kisielisodd
- ECUMASTER TEAM
Re: vvt map
calvin briggs wrote:hi there, i am looking for a VVT map for the ford duratec 3.5 V6... I know that you have tuned one such engine and i was wondering if you could share the VVT settings and the method which you used to achieve them. This engine has vvt on the two intake cams only. Thanks
Please don't get angry. Firstly You didn't asked personally, just generally. Secondly You Asked question in DET3 section which apparently applies to EMU, so maybe no one understand You. Thirdly forum serve rather as a place where users are sharing knowledge and experience. If You need direct answers please contact local dealer or general tech support (tech@ecumaster.com). if you did not get answer, it means that we could be busy or we just miss Your question.
