Serial input on ext. port
Ralf
Post by Ralf » Wed Oct 21, 2015 9:08 pm
is there any possibility to input sensor data via the RXD line of the extension port using the ecumaster serial protocol, for example EGT value?
Regards, Ralf
Re: Serial input on ext. port
Post by PSI-Motor » Wed Oct 21, 2015 9:31 pm
Yes there is a CAN egt box you could use that allows for 8 egt.
Ralf
Post by Ralf » Wed Oct 21, 2015 10:27 pm
EGT was just an example. Could I also use the ecumaster serial protocol for that? I already use the serial protocol output to display values on a touchscreen using some microcontroller hardware with my own firmware. As I don't have any analog inputs left on the ECU connectors, it would be an advantage to get for example oil pressure and oil temperature into the ECU via the serial line.
Post by Jadzwin » Thu Oct 22, 2015 9:42 am
Hi!
What channels are you interrested in ? I think it would be possible for Oil/Fuel pressure and Oil temp
Ralf
Post by Ralf » Thu Oct 22, 2015 6:47 pm
Hi Jadzwin,
that sounds good, relevant channels would be oil pressure and oil temp, but at least one EGT channel would be even more important for me. Is that possible?
Thanks, Ralf
