I'm currently installing the DET3 on my ride : a Mitsubishi Colt/Mirage CA5a Gti with the 4g93 n/a engine.
First of all, it's really dificult to understand the user manual, many things are missing, and it's very hard to understand the "philosophy" of the product.
i need some clear informations :
-i have 2 softwares : The Det3 client and the Fuel implant Det3: which one using ?
In the first one, some options are availables in some menus, not in the second one ! why ?
-I'm planning to remove the MAF from the engine and transform to MAP: what is the sensors do in need to connect to the DET3, to let the DET3
creat a correct map ? i've connected the MAF signal (well interpreted by the DET3), but how about the others signal ? which ones are mandatory ? rpm ? TPS ? ignition ?
Nothing is mentioned in the user manual about this !
- How about the RPM ? is there any RPM connector ? or do i need to let the DET3 generating the RPM graph with the signal from the ignition ?
Thanks for your help !
