Oxygen Sensor LSU 4.2 shows only 1
dontriple
Post by dontriple » Mon Aug 08, 2016 4:33 pm
i have a problem since 2-3 Months with my second EMU,
AFR/Lambda shows only 1
ive checked 100 times the wiring, changed the Laptop, changed the LSU :(
Can u help me maybe? it has never been shown something else than 1 :(
my other EMU works perfect :)
here u can see my settings / ive tried things like enable when no rpm
dontriple
Re: Oxygen Sensor LSU 4.2 shows only 1
Post by dontriple » Thu Aug 11, 2016 5:43 pm
Please help :) Where are the EcuMaster Gurus
Post by RHD » Sat Aug 13, 2016 5:44 am
you can try swapping your ECU's ... but it can only be a wiring or a sensor problem
dontriple
Post by dontriple » Thu Sep 01, 2016 10:14 am
we swapped yesterday the ECU and it still shows Lambda 1 / Ive transfered also the ECU Files from my working ECU to the other and no chance :(
Lambda shows still only 1 ..... Please guys give me a last hope :P
pric
Post by pric » Thu Sep 01, 2016 6:14 pm
Must be something with the wiring.
Maybe no supply on the Sensor?
Mercedes C280 M104 Turbo
dontriple
Post by dontriple » Thu Sep 01, 2016 7:24 pm
But i swapped the ecu and than it works, i have 2 cars running on emu. And the one is not working since ive bought it
Post by PSI-Motor » Thu Sep 01, 2016 10:15 pm
dontriple wrote:But i swapped the ecu and than it works, i have 2 cars running on emu. And the one is not working since ive bought it
Send it to your reseller and he will fix it.
dontriple
Post by dontriple » Fri Sep 02, 2016 8:08 am
OK, than i will send it to the reseller in some weeks because i need the car :)
One last hope:
1. Are the Outputs/Inputs for the LSU 4.2 one the ECU fix ? Or can i change them?
2. on my Log all values are moving except of the AFR/Lambda, my this help :)
dontriple
Post by dontriple » Mon Sep 12, 2016 11:01 am
:roll:
Kisielisodd
ECUMASTER TEAM
Post by Kisielisodd » Mon Sep 12, 2016 11:51 am
1) wiring problem
2) power supply issue
3) damage sensor
No readings at all from the sensor.
dontriple
Post by dontriple » Mon Sep 12, 2016 12:22 pm
1) Wiring problem it can not be, because it works with my other EMU
2) Sensor problem, the same
3) Power Supy, the same
IT must be something with the EMU / U know mybe how i can check this ?
Kisielisodd
ECUMASTER TEAM
Post by Kisielisodd » Mon Sep 12, 2016 1:25 pm
dontriple wrote:Hi,
So finally is lambda working on other ECU or not ?
dontriple
Post by dontriple » Mon Sep 12, 2016 1:31 pm
Yes it works on other EMU /
dontriple
Post by dontriple » Mon Sep 12, 2016 1:33 pm
I meant that i swapped the "BAD EMU" to my other car, where everything is working perfect.
And it still dont work
So it must be something "INSIDE" the EMU :/
Kisielisodd
ECUMASTER TEAM
Post by Kisielisodd » Mon Sep 12, 2016 4:51 pm
Ok understand, there may be a internal malfunction, the only way to confirm damage unit, is to send it back.
dontriple
Post by dontriple » Tue Sep 13, 2016 9:15 am
Ok than i will send it back in 1-2 Months,
but mybe can u give ma tipp how i can read mybe in a other way the Lambda ?
Which of this values will show me the Lambda in Volt ?? Or will my plan not work :D
