Aux outputs not working
I am trying to hook up a fan to a relay through one of the Aux output. I can set it up in the ECU and see it function on the lower status bar but there is no voltage coming out of the ecu lead that I set up. Tried all of the the available outputs to no avail. Any thoughts would be greatly appreciated.
Jean Niemi
- Contact:
Re: Aux outputs not working
Yes, when everything else fails, it is time to read the manual
(AUX outputs switch to ground.)
