Need help to setup the car better, please review and tell me what can be improved.
Also, antilag and launch dont work ok, or i cant setup them properly ... antilag dont work at all, i tried cam 2 inverted and normal, and put button on clutch ... when press, nothing happen. It works for launch but n for als. Also ve, enrichments ... idle ... if somebody can help, please see tune and log and tell me what you think and what can be changed.
sr20det tune help pls
- 3rd gear run.emulog
- this is made on 3rd gear full throttle
- (58.93KiB)Downloaded 60 times
Re: sr20det tune help pls
here is the tune
- s14 240sx sr20det.emu
- here is the tune file
- (100.67KiB)Downloaded 118 times
- Kisielisodd
- ECUMASTER TEAM
Are There any issuer with tune (except ALS ?) no power ? timing looks good, lambda fallow target, No ignition errors ... There is a fuel cut on log file, and signal is noisy. My advice to solve those 2 problems is, to move fuel cut higher or use furl cut above pressure delay option, and use map sensor filter table with mode 3 filtering, in higher RPM.
Which mode smooths out better the map signal?Kisielisodd wrote:Are There any issuer with tune (except ALS ?) no power ? timing looks good, lambda fallow target, No ignition errors ... There is a fuel cut on log file, and signal is noisy. My advice to solve those 2 problems is, to move fuel cut higher or use furl cut above pressure delay option, and use map sensor filter table with mode 3 filtering, in higher RPM.
We think power is ok, just its first tune, so need advise on other tables like warmups, enrichments etc ... and help for the ALS control ... also what you think about afr and target ... too rich, can we lean? Or its ok like it is. Need help from pros for first tune, because not sure how it should be, and what is good to be done.
Be very carefull using ALS on SR20DET engine. Its very easy to get damaged.
