I currently building my mkiv 2jzgte supra with a compound turbo setup. I have 2 wastegates with different functions. To control the big turbo I want to use the normal boost control function with the first solenoid. The small turbo must be also controlled by the ecu, but which output do I have use to do that? trough which output can I control the second solenoid and adjust the solenoid DC% like the first solenoid? picture attached with the setup so you can see why I need to control the wastegates separately.
thanks,
Tim
