Fuel cut idle help?
flubyux2
Fuel cut idle help?
Post by flubyux2 » Thu Nov 26, 2015 7:00 am
I have my als working with the default settings. I don't care too much for the als. I really want the fc idle to cool down between pulls though.
But my fc idle won't cut injector. It's just surging.
And it won't time out. It will surge continuously unless I disable fc idle control.
When I first enabled fc idle, it was successfully cutting injector and now I can't achieve it again.
Anyone have some 2jz settings they'd care to share?
Kisielisodd
ECUMASTER TEAM
Re: Fuel cut idle help?
Post by Kisielisodd » Thu Nov 26, 2015 12:24 pm
Without configuration file We can't help
flubyux2
Post by flubyux2 » Thu Nov 26, 2015 7:20 pm
Post by Jadzwin » Wed Dec 02, 2015 1:08 pm
How does your idle - cut fuel table look like ?
Can you send log with fuel cut idle ?
flubyux2
Post by flubyux2 » Wed Dec 02, 2015 10:34 pm
when you mentioned fuel cut idle table, it reminded me that I zeroed all my settings on it while trying to figure out why my Aux switch issue.
I restored the settings on the fuel cut idle table and its operating like it should. the whole ALS strategy is now functional. but now im back to my original switch issue. I can start the car with the switch off and the ALS wont operate. then I can switch it on, ALS operates. but, switching it off with the switch does not turn off the ALS strategy. the only way to disable ALS is to shut the car off and restart it with the switch in the off position.
I wired It according to the diagram for using Cam2 input. I enabled the pullup and its set to VR sensor if that matters.
1jz_440cc_starttest.emu
(95.96KiB)Downloaded 110 times
20151202_1337.emulog
(978.58KiB)Downloaded 120 times
