No injector or coil output 2JZ
rintegration
Post by rintegration » Sat Dec 12, 2015 8:01 pm
Hello I'm working on a SC300 with a 2JZGTE and I cant seem to get injector output or coil output. While cranking the cam-crank is synced but I get no injector duty cycle or coil output. I'm running GM LQ9 coils. I have triple checked my wiring and everything is in place. I have manually trigger the coils and injectors so Im sure there good. It almost seems like something in the ECU for these two outputs is turn off. Ive looked through everything and now Im just stuck. Any valid input would be appreciated.
GrzesiekK.
Re: No injector or coil output 2JZ
Post by GrzesiekK. » Sat Dec 12, 2015 10:07 pm
If you can, please share your emu project. It will be easier to help you.
Greg
Scooter
Post by Scooter » Sun Dec 13, 2015 2:19 am
My injector phase is set to 3,1,5,4,6,2 and my ignition outputs are 2,4,6,5,3,1....try that order
Scooter
Post by Scooter » Sun Dec 13, 2015 2:23 am
Also, what settings are you using in the Coil Dwell wizard? ....I think single fire, 5A, 25.4mJ is what you want selected
tommyboyblitz
Post by tommyboyblitz » Sun Dec 13, 2015 4:08 am
i had the same problem with my 1jz, you also have the same trigger teeth etc, can you upload a scope and a map so we can look?
The problem with mine was the EMU itself, I doubt its the same problem though mine was second hand and the guy i bought it from really messed up the wiring.
Post by RHD » Tue Dec 15, 2015 5:12 pm
you can log executed spark count and injector PW to see if ecu is actually sending signals
