Hello
I have a problem with my vr6 engine.
i think i have problems with my trigger signal because when i drive on the railway sometime lost the signal.
and a other problem is my engine can not rotate above 6600 rpm.
my rpm limiter and fuel cut etc is 7300.
maybe anoyone has so idea , why the engine cant rotate to the rpm limiter.
Greetz
Cant rotate above ~6600 rpm
- log1.emulog
- (1.96MiB)Downloaded 93 times
Re: Cant rotate above ~6600 rpm
In your log are a lot of tuning faults to see.
Dwell time is wrong when you use the wasted spark VR6 ignition module.
Warmup enrichment at CLT of 82°C and IAT correction of 22°C ???
Your ignition angle at low loads are everytime nearly the same and very low.
Please make a scope of your trigger signals and post config file here.
Sorry but i dont understand..
What do you mean with the warmup enrichment 82 c. And ias correction 22 ?
here is mein config file and scope
- scope_20151216_2012.emuscp
- (248Bytes)Downloaded 82 times
- file.emu
- (96.14KiB)Downloaded 80 times
ign map looks back to front to me , 45 degree at high boost and rev ?
It is not a trigger problem. There are no evidence of any trigger issues.
What is your spark plug gap ? Maybe you should increase dwell time ?
What is lambda / AFR ? On log there is 8. Eventually what fuel do you use ?
Hello I found the problem why not turn higher . with gear sensor input I have an analog cable lock attached , but it was not active (see picture) .
When I put this out , has all works as it should .
