subaru EJ20 BASE MAP
janko
Post by janko » Mon Aug 29, 2016 11:38 am
Can someone share base map for Subaru EJ20 GC8 MY98 ? Or at least idle control and cold start-up maps? It takes more then 10 minutes to start when cold....
You can send me PM if You don't want Your map to be Public!
Best regards, Janko
ren
Re: subaru EJ20 BASE MAP
Post by ren » Mon Aug 29, 2016 10:39 pm
Post the calibration you are using at the moment - I reckon your temperature compensations will be off, and after 10 minutes, with the heat you have managed to make, you are getting closer to the required fuel/air/ign setting.
philsinc
Post by philsinc » Tue Aug 30, 2016 8:41 pm
hi, i have a basemap from my ej20 my97 with 440cc injectors. coldstart could be better but it works for starting the engine.
janko
Post by janko » Thu Sep 01, 2016 5:25 pm
philsinc wrote:hi, i have a basemap from my ej20 my97 with 440cc injectors. coldstart could be better but it works for starting the engine.
Hi, i sent You PM!
Dimi6274
Post by Dimi6274 » Sat Oct 08, 2016 9:38 pm
I have problems with crank sensor calibration.
The car doesnt startup the most of our tries.
We have connect the ingition and injectors in full sequential way.
Do you have a startup calibration to help us?
Thank you in advance
chicoman
Post by chicoman » Wed Mar 01, 2017 8:28 am
Hi!
Would You be so kind and share the map on PW.
Just finished wiring loom on cg8 my99, time to get started.
