We install VVTI as told in this forum.
Engine cant REV above 4000 RPM.
Then we uninstall VVTI and load back MAP previous to VVTI.
It is the same, engine only can REV around 4000 RPM.
What can be wrong?
Enclose MAP and LOG files.
Engine REV Problem
paryoto.semesta
- log_300916.emulog
- (1.38MiB)Downloaded 75 times
- map_300916.emu
- (99.12KiB)Downloaded 68 times
Re: Engine REV Problem
try to set sensitivity swich in CAM input to 2000
paryoto.semesta
I scroll down from "sensor setup" to "gauges".
Cant find "CAM input".
There is no "CAM input" in VVT ---> CAM 1 Control.
Where is it?
Where is it?
paryoto.semesta wrote:I scroll down from "sensor setup" to "gauges".
Where is it?
Ignition - Secondary trigger
paryoto.semesta
Try all possible options.
Still unable to REV beyond 4000 RPM.
Just turn off this feature and work fine.
Thanks for help.
Thanks for help.
