Hot Starting on 3sgte 2nd gen
rockyboist
Post by rockyboist » Tue Oct 18, 2016 5:26 am
Hi, I need help with it as it doesn't start when engine is at the operating temp. In order for it to start I will have to let it cool a little, when the water temp goes down less than 70 degrees I could start the car again no issues. Car starts perfectly when cold.
It cranks but does not continue/fire. Sometimes when I keep trying it will start but that's just luck. No pattern observed.
Attached are the logs and scope. Can someone help please? Any suggestion? I have tried the below to no luck:
- Trimmed and added in VE table
- Trimmed and added fuel in Engine Start
- Prime pulse (enabled/disabled, addedtTrimmed)
- Batch injectors (enabled/disabled)
- Changed dead time in cranking fuel (added/trimmed), and matched it close the PW
- Changed Cranking IGT
- Changed injector dead time under Fueling to what I had on the cold temp
- Adjusted ignition in the IGT map (added/trimmed)
scope_20160926_unable to start scope.emuscp
Scope file not starting just cranks
(513Bytes)Downloaded 109 times
20160926 unable to start logs.emulog
Log file not starting just cranks
(6.7KiB)Downloaded 118 times
silikone
Re: Hot Starting on 3sgte 2nd gen
Post by silikone » Tue Oct 18, 2016 12:16 pm
check ''secondary trigger'' settings
you have problem with camsync
rockyboist
Post by rockyboist » Tue Oct 18, 2016 11:57 pm
Thanks for the response, here's my secondary trigger settings, what do you suggest needs changing there? I remember the enable advanced filter was not checked before but I had some issues that if I hold the throttle at 2k rpm, the rpm fluctuates going up and down. Enabling it and putting 24 in the trigger tooth resolved it.
silikone
Post by silikone » Wed Oct 19, 2016 10:31 am
do you tried to disable the filter?
check your sensor wiring, shield...
rockyboist
Post by rockyboist » Thu Oct 20, 2016 4:47 am
Tried disabling, did not work. What sensor to check and how?
pepifebles
Post by pepifebles » Thu Oct 20, 2016 8:12 pm
Upload your project. Think that your dwell time and cranking afr is too high. Probably there is other problem but that sets don't help.
This is my gen 3 secondary trigger.
The fun starts now
silikone
Post by silikone » Fri Oct 21, 2016 10:01 am
engine does not start because the ECU does not see the signal from the camsensor
EMU is not synchronized. Injectors will not open.
how you connected the sensor?
maybe your camsensor is broken?
if wiring is OK, try connect pulldown to signal wire.
pepifebles
Post by pepifebles » Fri Oct 21, 2016 12:12 pm
silikone wrote:engine does not start because the ECU does not see the signal from the camsensor
Why start with cold temp? If no read or broken sensor, dont start never.
I think that any set its wrong.
The fun starts now
silikone
Post by silikone » Fri Oct 21, 2016 12:27 pm
Look at the logfile and scope. No signal from cam.
Welshman
Post by Welshman » Fri Oct 21, 2016 12:36 pm
would help if he posted his map
pepifebles
Post by pepifebles » Fri Oct 21, 2016 1:03 pm
Welshman wrote:would help if he posted his map
Exactly
The fun starts now
Post by RHD » Sat Oct 22, 2016 10:55 am
i think your cam sensor is broken, often faulty electrical components are affected by heat
rockyboist
Post by rockyboist » Mon Oct 24, 2016 8:58 am
Ok I'll upload the whole project later. Thanks for the help guys.
rockyboist
Post by rockyboist » Tue Oct 25, 2016 2:39 am
Here's my map/project uploaded, can you take a look guys and let me know?
I'll try a different distributor and see if it helps. I noticed I could start it even when it's hot if I rev the car for say 4-5 times up to 3-4k rpm before I turn it off, it will fire right up.
oct 24.emu
Project EMU file
(96.12KiB)Downloaded 118 times
gips
Post by gips » Sat Oct 29, 2016 11:43 am
It can be a faulty EMU. I had the same problem , although mine never got started at all. There was no cam signal at all, no matter cold, or hot, so be advised. Ecumaster replaced some chip in the EMU and its working flawlessly since then :)
rockyboist
Post by rockyboist » Mon Oct 31, 2016 8:26 am
gips, I hope that it is not. I am yet to replace my distributor and test.
