hi i have started my 2jzgte and am trying to adjust the static timing.
i put a hi tension cable between my coil and plug and connected the timing light but am not getting the flash.
i tried the timing light on another car and it works. i then took 1 hi tension from this car and plugged it into the 2jz but still no flash.
am i doing something wrong here?
thanks
timing light
boostedkane
Re: timing light
i got the light to work. all i had to do is not close the clip over the wire and leave it open. i then altered the ignition to match actual ignition which i had to move the trigger angle to 88. but for some reason which i cant seem to solve i randomly loose sync for an instance.
the file for the log is too large to upload here. so maybe i can email you it or something?
help us much appreciated
- try3.emu
- (101.19KiB)Downloaded 87 times
- scope 1.emuscp
- (81Bytes)Downloaded 95 times
Re: timing light
You will need to change falling / rising so that you get tooth 2 and 66 degres otherwise something is wrong.
Did you wire it in yourself or is it a pnp?
boostedkane
Re: timing light
i did all the wiring my self.
so i should change my first trigger tooth from 3 to 2?
yes i did lock it at 0 and i had to adjust to 88 deg to align to 0. but i also noticed that the mark is moving. i have a sync problem also. if i can send you a log you might understand me better
boostedkane
Re: timing light
solved the sync error all it was is a bad crimp.
but still cant get the timing right.
i tried swapping over my trigger wires around and still no luck.
Re: timing light
Please find proven 2JZ base map with correct timing.
https://dl.dropboxusercontent.com/u/286 ... nector.emu
Here is also pinout how EMU is connected for the base map attached
https://dl.dropboxusercontent.com/u/28620292/2jzgte.pdf
boostedkane
Re: timing light
thanks but it is sorted now,
i had faulty coils.
swapped to a new set and no problem.
have had the car running a few hours with minor issues
the lambda occasionally goes to 1.98 and stays there for about 30 seconds than starts working again
i dont know how to wire in the oil temp sensor or the fuel level sensor
i had faulty coils.
