hey guys i need help wiring my temp sensor. it is a simple bosch ntc 2 wire sensor exactly like the coolan one but when i wire it like the coolant sensor i get no reading. i was looking at the ecumaster help and it says to make a pull up resistor. how do i do this and what resistor should it be?
i am also not being able to operate my fuel level sensor. it is also 2 wire but dont seem to understand the wiring of it.
thanks and regards kane
oil temperature sensor
Re: oil temperature sensor
you can try adding a resistor from the analog input you are using to the 5V signal voltage output on the ecu, try 2K but you may need lower or higher to get better resolution on your input voltage range, it all depends on the resistance in the sensors
boostedkane
thanks for your help again, i did just as you said and it worked for both my sensors.
