I am new to the ECU Master. Can someone help me with a base map so I can get started and get on the dyno. 1.5 JZ with GTX3076 and 800cc injectors. Not that it makes a difference as I should be able to modify the map sufficient to drive it on the dyno.
Thank you.
1JZ VVTi request base map please
Re: 1JZ VVTi request base map please
You'll need to check ignition configurations (number and style of coils), injector settings, vvti solenoid assignment, etc., but this map should be a workable starting point.
- VVTi 2JZ.emu
- (85.68KiB)Downloaded 144 times
I am interested in getting the ecu master emu for my car ( JZZ30 SOARER 1JZGTE)... My car is 100% stock and would like to know if I have to arrange settings for the car to start? And is there a large enough community to educate about to know this ecu inside and out
I was in the same position. The people in this forum are very helpful. I have found all the information I needed to make my engine run. The ECU is good and very capable.
