EMU Black V3 base map for Ford Focus MK2 ST225
This base map is intended for EMU Black V3.
To learn more about the new V3 software and the migration process, refer to:
EMU Black Migration Guide to V3 Software
Description
Base Map
Scope
Inputs and outputs assignment
The map was calibrated on a dynamometer:
Peak power: 260 HP
Peak torque: 461 Nm
Peak boost pressure: 100 kPa (1.0 bar)
Setup Details:
EMU BLACK V3 (firmware 3.066) + Ford Focus MK2 adapter (including accelerator position sensor adapter)
These baseline maps provide a starting point for tuning and are designed for specific engines. They are not guaranteed to work correctly out of the box and may require adjustments to fit your particular setup. Always treat these maps as a foundation to build upon and make further refinements as needed.
