EMU PRO base map for BMW B58TU Gen 2
BMW B58TU Gen 2 Engine
This configuration applies only to the B58TU Gen 2 engine itself and does not include any vehicle-specific settings.
Be sure to configure all additional components such as the low-pressure fuel pump, cooling fans, starter, and other auxiliary systems.
This base map is intended only for BMW B58TU Gen 2 engines.
Injector calibration, high-pressure fuel pump calibration, and high-pressure sensor calibration differ significantly from Gen 1 and are not compatible.
The attached map controls the following:
– GDI injectors
– GDI high-pressure fuel pump
– Alternator control using a LIN signal
– Closed-loop of the oil pressure
– Electronic throttle
– Knock control
– Fuel rail pressure sensor with SENT protocol
– VVT solenoid control
– Electronic thermostat closed-loop temperature target
Setup Details:
EMU PRO-8 + GDI Driver
Description
Base Map
GDI Driver configuration
Scope
Inputs and outputs assignment
These baseline maps provide a starting point for tuning and are designed for specific engines. They are not guaranteed to work correctly out of the box and may require adjustments to fit your particular setup. Always treat these maps as a foundation to build upon and make further refinements as needed.
This base map requires EMU PRO version 226.0.
You can download this version from the product website: https://www.ecumaster.com/products/emu-pro/
The map was calibrated on a dynamometer:
– Torque: 420 Nm
– Boost pressure: 50 kPa (0.5 bar)
Non-mapped or unsupported features:
– Valvetronic control is not supported and requires a fixed lock at the maximum intake valves opening.
